building corner cutaway
2305.1
Hi
I modeled this in MoI ... transferred it to Rhino and then assigned layers and brought it back to MoI for some touch up stuff.
I was delighted to discover that my layers stayed in place in the movements back and forth between the two programs (I really expected MoI to lose the layers assigned in Rhino).
I went back to Rhino for assigning materials (Flamingo) and then rendered it with Flamingo. Of course, Moi did not keep the assigned materials when I did another experimental switch back and forth.
For notes and dimensions I will probably use PhotoShop unless I can find a simpler method.
Michael, I did have some problems with 'array' adding duplicates (in exactly the same position ... so invisible) and in one case removing the source object. Perhaps I 'clicked' more than once though I was not aware that I did.
cheers,
eric
Size: 56.7 KB, Downloaded: 96 times, Dimensions: 1100x613px
