Requests, lots of it.
230.6 In reply to 230.5
Hi Tony - don't worry, none of these things will ruin the current simplicity of MoI. That's why I mentioned that major new UI will take a while to develop, I'm not going to just stick something in that doesn't work smoothly.
> if you ever introduce a scene broswer please make it as an option.
It would take the form of either a collapsable panel like you mention, or there will be a switch to flip the side bar between either showing commands (like currently) or switch it to an object list display.
> The same for control handles. :) Please make them as an option.
They will probably be pretty unobtrusive, probably partially transparent unless you move your mouse over them. And there will definitely be an option to turn them off it you don't want them.
It will probably be a while before these things come anyway.
> I think the camera controls are ok. I'm happy that i do not need to press
> x+x+x buttons to zoom,rotate and pan.
I'm not going to take that away, I'm just going to add additional ways to do it.
> Btw. i have a request and it's just one. ;) I would like to change the camera FOV.
How would you think to set it? I mean do you want to set the FOV to some particular numeric value on a dialog, or are you talking about some kind of dynamic adjustment with the mouse?
