Requests, lots of it.
230.10 In reply to 230.9
> could you add it to the Options as a slider like the UI-Size slider ? Or just
> make it dynamic changeable with pressing key "whatever" and moving
> the mouse. Maybe this is a better choice than a dialog.
I was thinking ctrl + mouse wheel... I'll add this to the list to try and jam into the beta after the next one.
> Would it be possible to show only the icons in the sidemenu without the text under them?
I should probably be able to make an option for this in the 2nd next beta as well, probably. In the meantime, you know how to edit the UI files, right? So you can just go in there and delete the inner text in SidePane.htm if you want to see it right now.
