The model has to be a solid or else it won't print. You should also not model any part that is less than the printers recommended tolerence. Where I get my stuff done, that minimum is around 1 mm thick. So the nose spike is 1.2 mm diameter and the wings at their thinnest points are greater than 1 mm as well.
