| Hi Michael,
 In version 2 (beta) the on_screen default rotate widget can be used with the "ctrl" key pressed which will create a copy. When you click the rotate widget it then changes to the orbiting rotate handles, but, when pressing the "ctrl" key when rotating using those orbiting handles there is no copy of the object created.
 Could you please add that option, so that pressing the control key will produce a copy when using either type of on_screen rotate.
 - Steve
