suggestion, Isolate command
2201.24 In reply to 2201.7
Personally I'm hoping for hide and show to get a lot better with the group/layer/object organisation in V2.
I am hoping to be able to hide and show groups of objects. So I would be able to have construction curves in a separate groups that can be shown or hidden as required. Is this the case?
If so then the current hide/show can remain quite simple. Modo has the same function but is very simple. Hide or show all. Only really used on the fly to get things temporarily out the way. The object organizing system (in modo's case layers and groups) takes care of any other hide show situations.
Your left-click/right click for different functionality (hide/isolate) sounds confusing to me. If they are different commands and you still allow changing the UI as you did for V1, then I would probably try to put them on different icons.
