Quick suggestion about the Grid Snap setting...
2195.6 In reply to 2195.3
Bonjour Michel,
> It certainly would be nice to have both possibilities.
Ok, I will keep those as separate things to control. They are actually currently available as separate things on the full Options / Grid dialog that has all the grid settings on it.
If you'd like to give the updated Grid mini-menu a try, you can get the updated UI for that in the previous message here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2195.5
> Would it also be interesting to be able to enter a factor of
> enlargment or reduction like (ex. : /2 or *2 ) in those boxes ?
That should actually work right now if you leave the current number in place, and add the /2 or *2 after it, since you can enter numeric expressions.
So for example if you have a size of 5, add the /2 after it so the whole expression looks like 5/2 .
But I think that would be nice to be able to enter a special "modify existing value" notation like you show there, and probably that will not be too difficult for me to add. I will put that on my list of things to try and get in for the next beta.
