| Hi Will, well that is such a small menu it is not a problem to expand it in size to hold some additional controls.
It is a good spot to have alternate access to some of the most frequently used grid settings instead of pulling up the whole Options dialog that has all the settings on it.
Here is what I changed it to:
Does that seem like it should do what you need?
If you'd like to try it, you can update your current version to have this by copying the attached GridSnapMenu.htm file over top of the old version in the \ui subfolder in MoI's main installation folder.
EDIT: updated GridSnapMenu.htm to reverse the order to put Snap size above grid size, and enable auto-focus. This means that after you pop up that menu you can immediately type a number after that without needing to click in the control first.
    - Michael |
