Skp export setting request
2180.1
Just started testing V2. I like it already...
The SketchUp export is great, but could you make the default settings limit the smallest triangle size so that all faces will be created.
SketchUp won't create a face if the triangle is too small, but I don't know how big it needs to be. Here is a small image showing the problem, and as you can se the same shape when exported at a biger size from MoI will not have the holes that were present in the original export.
Sheik
Size: 176.8 KB, Downloaded: 93 times, Dimensions: 816x513px
