Hi Brian, it sounds like there may be a bug in v2.
Remember v2 is a beta release and not a finished version so it would not be very strange to have a bug in it!
Since you say that Nudge is working properly in v1 then for now you may need to switch to v1 when you need to do Nudging, that would be an immediate solution to your Nudge problem.
It is a good idea to keep v1 around so that you can use it when you run into any bugs or problems in v2!
But probably the specific thing that is making V2's Nudge not work is that you haven't installed that custom command into V2 yet.
If you go to the \commands folder in V1's program files folder, you will probably find a file there named Nudge.js which you had added in to your v1 installation earlier at some point.
If you copy that Nudge.js file into the V2 beta's \commands folder, that will probably fix up your v2 to do Nudging as well I think.
Can you try copying that file over, and let me know if that makes Nudging work on your v2 installation after that?
If so, then that would let me be more sure of what the problem is.
