Modeling problem question....how would you model this?
2164.7 In reply to 2164.5
> Is there a way to view the model as shaded only, ie...no
> wireframe/goasted parts, just smooth object?
If you're using the v2 beta, go under the View tab on the side pane and uncheck "Display hidden edges" to turn off the dashed hidden line display.
Then if you want to temporarily get rid of the non-hidden edge display as well, you can do that with a keyboard shortcut. There are 2 different ways you can do it, you can use the script on Petr's page here:
http://kyticka.webzdarma.cz/3d/moi/#ShadedDisplayMode
which will hide all edges (it's the same as selecting them manually and using Edit/Hide to hide them), or another way which I actually use is to set up a keyboard shortcut to save to a polygon file format, and on the meshing dialog there you can choose the option for Display: Shaded there.
To do that, set up a shortcut key with this command:
SaveAs c:\test.obj
That can be a handy shortcut for checking what the meshing looks like at various times when you are modeling as well. Just hit escape or push the cancel button to bail out instead of actually writing the "test.obj" file out.
At some point I'm going to have more display options listed under that View tab.
