> No unity (cm, mmm...) somewhere?
Actually I do have those now - I just had my units set to "No unit system".
If you have units set, a small label will appear at the end of the Size: control:
Also units labels will show up in the bottom toolbar after the x,y,z point and distance controls:
And also after distance/length type input fields in command options, like here is one for drawing a circle:
> Colors can be chosen ? (define)
I'm not sure... I probably won't be able to do any kind of GUI editor for them but maybe read them in from a text file that you could customize if you want.
> What meaning "CRV"?
It's short for "Curve". There is not much space in that area, so I have needed to use some contractions there.
