Batch file conversion
2100.6 In reply to 2100.4
Hi John,
> gd.saveAs( OBJFileName, 'NoUI=true' );'Angle=3.0'
The way it works is that you glue those options together all within the same '    ' quotes, putting semi-colons in between them, like this:
gd.saveAs( OBJFileName, 'NoUI=true;Angle=3.0' );
Everything between '    ' quotes is considered to be one string object - the options should be one string that has semi-colons in between the different individual options.
Another example with more parameters:
gd.saveAs( OBJFileName, 'NoUI=true;Angle=3.0;Weld=true;MaxLength=4;Output=quads' );
Also another note on the options - in the comments there are some things that are listed as separated by an | - that means "or", so you should only use one of those in those case. Like for instance the description of Output is like this:
// Output=ngons | quads | triangles
That means you can have one of Output=ngons or Output=quads or Output=triangles
Don't put in the actual | character for those ones.
Hopefully that will get you all set up?
EDITED: 20 Oct 2008 by MICHAEL GIBSON
