Hi Micha, also one thing to check - when I previously wrote that the new setting would be:
[Mesh Export]
PersistSettingsBetweenSessions=n
What that actually means is that there will be a new entry "PersistSettingsBetweenSessions", which will be under the [Mesh Export] section.
If you manually add that in, you need to find the existing [Mesh Export] section, and then paste the new PersistSettingsBetweenSessions=  line under that, don't add in a second [Mesh Export] section.
Also note that you'll need to make the setting say =y  instead of the default =n if you want the new persist behavior.
