Hi there guys,
I just bought Moi, nice program. I was reading through your posts, thanks for making the batch conversion utility. I actually bought moi to import geometry from Rhino to C4d using the obj format. Nice tessellation. I figured it out but I would suggest posting instructions on how to call a script. I ended up editing a shortcut of the moi.exe that I made for the script specifically. Also, would it be possible to tailor the script to just convert all the files in one directory instead of having to manually make a line for each file you need to convert?
I run a rhino script that saves each layer out to a separate file, would be nice to just save out all files in a folder from moi.
Thanks much
John Zapf
