mesh angle
2071.3 In reply to 2071.1
Hi Steve,
> I'm trying to get my head around the mesh angle.
You're talking about the Mesh angle parameter on the Options dialog under the View section, right?
> When I reduce the mesh angle, it only affects the display
> mesh and does not add zillions of extra actual data points
> to the model.
Yes, that's correct - it only controls the display mesh used at run-time and does not insert any additional points into the original surface or solid data, and does not do anything to data that is written to any file.
However, it is not very good to set this to be too small of an angle because that can start to consume quite a lot of memory for the display mesh (and also take longer to calculate), I would recommend not going any smaller than the default 10 degrees which is already quite a bit on the dense side to make a nice looking display. If you have a complex model bumping this up to 20 or 25 degrees can help to speed up the display if it is bogging down.
> In other words, if I export as .stp or .igs, it makes no
> difference what my mesh angle setting is or has been during
> the construcion of the model.
Correct. And actually the .stp or .igs export contains NURBS surface data and not mesh data, so nothing involving meshes at all really comes into play when exporting to these formats.
> If I export polygon data, I can control the level of meshing
> quite finely with the export mesh dialog.
Correct - when you export to a polygon mesh file format a completely new mesh that has nothing to do with the display mesh will be calculated.
The display mesh is actually a somewhat messy mesh, it is oriented towards calculating a result very quickly and tends to try to get a dense result as quickly as possible.
The export mesh does a lot more intensive number crunching to calculate a higher quality mesh that has stuff like more evenly spaced points in it. It is not very feasible to do this for display purposes since it takes a long time to calculate, you would have a significant pause after every operation if it tried to do this for the display mesh.
So yes, you've got everything right there, the display mesh system is a separate thing from the export mesh, and the display settings do not have any effect on saved data of any type.
> BTW I love the way you have set up the meshing options
> for polygon export, it really works well.
Thanks, I'm glad you like it!
