Simplify lines or arcs
2051.12 In reply to 2051.10
Yes Brian
That's about what I'm aiming for. What process did you use? Does your flat sheet have thickness?
I'll probably fillet some of the edges.
The object will eventually be produced in a vacuum moulding process from 3 or 4mm thick ABS (probably) sheet. So part of the problem is to try and predict how small the letters can be before we start losing definition.
Steve
