| Hi kevjon,
 I can understand your frustration on this. Myself, I am the complete opposite to yourself, as I come from a background of using nurbs packages. I did move on to trying poly programs and found them very limiting to what I was used to. It did take quite a while before I was comfortable with poly programs before I added them to my pipeline (for home hobby), but even now still prefer nurbs.
 I do agree that MoI could be seen as limited in the toolset, but that is down to possible comparison with other packages, (and there is also a need to consider the price on those other packages), but what is within MoI works quite well,  various functions that are missing, such as the variable fillet you mentioned, can quite easily be worked around using such as the blend, which, although at times it cannot be used well directly with split surfaces, it is just a need to blend projected to surface construction lines and sweep.
 I will try and find time tomorrow to build in MoI part of the model you mention.
 Regards,
 - Steve
