I need some help please.
2021.5 In reply to 2021.3
Here's a file so you can visually see what I said.
These curves are very random as I just did a draft trace of your posted picture. If you use the original curves (remove any corner points) and create a profile curve for the face that is "smooth" with no corner points, this should give you a nice surface to cut the base object with.
Good luck. (Rammstein or what?)
Your english is good.
