Hi Eric - yes that would work, once you had things arranged in a regular grid then Network could handle it.
But yeah for your purposes that is probably a more labor intensive way to go rather than using a different tool for this.
Basically the way that Network work is similar to doing a loft in 2 directions. As part of the Network calculation it actually does create a loft through the latitude "U" curves, and then another loft through the longitude "V" curves and then those get merged together.
If your curves are not configured so that they can be lofted in each of these directions then it won't be able to handle it.
