Hi Jeff, thanks for testing the FBX into Max Design 2009
> However, when I try to render it crashes 3ds Max. I say
> it crashes, in reality 3ds Max simply disappears from my
> desktop. This issue only happens when I try to render an
> imported .fbx file from MoI.
Well that's kind of a bummer!
Can you test one thing please - when you export from MoI click the little arrow in the lower-left corner of the Meshing options dialog and try one version with "Weld vertices along edges" turned off and one with it turned on.
Does it only crash with the welding in a certain state, such as when it is turned on?
