Hi Marco - currently only the edge curves of a solid will be exported to AI format, it does not calculate things like silhouettes.
That is something that I want to add in the future, but it will probably be a while before I can make that happen.
If you need to do that right now, you can import your solids into Rhino and use Rhino's Make2D command to accomplish that.
