layers ,colors and groups with properties...
1956.1
There has been some ideas on how to make the organisation of
objects in Moi 3d possible .
I would love to see an organistion of the objects in 3 ways simultaniously.
grouping by color .... 1. dimension
grouping by layers 2. dimension
grouping as a group object 3. dimension
the nearest program that does this kind of organisation is Sketchup.
grouping by group object should be savable and have the possibility of anotation as well as properties.
Some of these properties could be snapping properties or normal to surface properties etc(or sliding on an axis).
Other then these properties it should be possible to store macros with itor short scripts.
plus a thumbnail of that group.
Now to an example :
You build a screw and make it a group object.
as a property it would have to always snap to surface normal plus second property would be to always snap to a surface
withn only the screwhead looking out (depth information)....
In the future if it were able to also store a macro it would i.e drill a hole into the surface it goes into and automatically
bevel that hole at the surface.
That would be future safe and save lots of work for prototyping.....
Those are just a few ideas that i had when braintorming....
Maybe not all for V2 but i think its good tol look into the future when nailing down the possibilities
hope thats not to confusing
Peter
