Smoothing where curves join?
1938.2 In reply to 1938.1
Hi gizmo,
Without a picture or 3dm file I'm assuming you mean after you mirror your curve they are not tangent and there is a 'kink' in the center, like in the picture below.
If this is the case then pick both curves (or if joined 1 curve) and turn on the control points by the command [Edit > Show pts]
You then align the 3 points that are highlighted in the picture by the command [Transform > Align > Horiz center]
those 3 points will then be in line and you can move that part of the curve up and down for a desired shape, once placed in position that curve is now tangent or 'smooth'.
Usually when drawing the freeform curve that you want to mirror and to be tangent or 'smooth' draw the last 2 control points in line, in that way when you mirror the curve you won't
end up with a 'kink' at the join of the 2 curves.
By the way this method is the V1 method the V2 method you can use the Object Frame to 'Flatten' those 3 points in line.
Hope this helps
