Object Edit Frame query
1930.6 In reply to 1930.4
Hi Petr,
> When I move a centre rotation pivot outside of object's bounding
> box I would prefer to have the rotation wheel bigger.
But how much bigger?
It I always made it bigger, then if you were zoomed in so the object was taking up much of the screen, the wheel would be larger than the current view so you would have to zoom out to use it...
Right now it just stays the same size as it was originally, which is a circle that will pass through the corners of the box.
Changing the size when you drag the origin seems like it might feel a little strange, the wheel would kind of hiccup instead of smoothly moving from its initial location.
