Hi Anis, those views that you are showing there are now possible to get in MoI as of the last Sep-21 v2 beta, because of the addition of the "3D view projection: Parallel" option that is now available under Options / View.
That combined with the ability to set the view angles under View / 3D view angles gives you all the parts that you need to get those particular view styles.
It should be possible to make a keyboard shortcut script that will set them for you with a single keypress, I will see if I can cook that up for you.
