Hi Nick, I guess just the regular traditional 2D illustrator "align" type tools have never really had a copy option on them, so I was just kind of following along with those.
The Align UI is a bit bulky already, that does make for a little bit of worry about adding more stuff in there...
Do you happen to have an example file where you wanted to use Align + Make copies mode? Are you certain that just regular Transform/Copy would not do the trick in that case?
