A couple of notes to Tab key handling:
Sometimes it works like Enter key so it finishes command instead of focusing on the next/first field.
For example, if you hit Tab key when the focus is on the last input field in second stage of Array/Grid (Y spacing) or in case of Circle or Ellipse/Corners command. On the other hand, Ellipse/Center handles Tab key as expected.
In other commands, it looks like the label is eating Tab key event - e.g. Array/Circular - try placing a mouse cursor over "Angle to fill" label and hitting Tab key several times.
Petr
ps: By the way, Opera 9.51 seems not to work properly with MoI forum. It doesn't mark messages as read until I log out. Has anyone encountered this?
