Shortcuts Problem V2
1861.2 In reply to 1861.1
Have you copied the command into the new betas command folder?
So for nudge, in your v1 commands folder, there is a file called nudge.js Look and see if nudge is in your beta dir.
"C:\Program Files\MoI 2.0 beta Aug-4-2008\commands"
Some of the other coomands have htm files that go along with them. be sure to copy those also if they exist. (Only if they were the custom ones from say petr's script pages).
It's kind of a process to keep up with the beta's and move all "Extra" scripts and custom work to the new beta.
You dont want to just overwrite any files which have changed internally for the new release, so you cant just overwrite all files. Only the extra's that are seperate from the default MoI install. What I do is keep a folder around and whenever I download or install a new command, I also copy it to this folder. I also have a text file where I create a line that is the shortcut I declared for this command. Then when a new beta pops up, I just copy the commands to the new betas folder, then I open the moi.ini file and paste in the text from the file where I saved the shortcut info. (everytime you create a shortcut and command you must add it to your "customize moi" folder and shortcuts file so when you install new version it's easier)
Burr
