I'm having a problem with this model. When I try to Boolean diff to get 2 halves it fails. If I Stepnudge it up a factor of .001 I cut it but with various flaws on the edges and not an equal cut.
Could be the way I made it causing issues.
I swept the polygon halves with the 2 rails and scaled it with the top one.
Then I swept the arc with the cirlce. (Scaled it up in z to meet the first part)
I mirrored both parts and joined them to get solids.
I trimmed the polygon odject with the torus, got rid of the artifacts then boolean union the 2 parts.
Ran join to creat a solid.
{Here's the catch}
Boolean diff the part with a line through the center fails unless I offset either a slight amount.
Is my construction method the culprit or is there another way I should try and cut this.
As I'm posting I figure the joining process is odd. I will re-attempt this by shortening the neck so it doesnt protrude so an initial boolean union should be enough. I will then try to diff with a line. (maybe answered my own question.
Any input is appreciated.
Yhanks,
Burr
[EDIT] I redid the creation by just shortening the neck and then I could just boolean union/join without all the trim first. It cut but when I zoom in it is still not centered (one half has a step) the short half is a nice result. Should I expect to be able to get equal halves with this process?[EDIT]
