Object name while OBJ exporting
1832.3 In reply to 1832.2
> Well, an OBJ file is just a regular text file that you can edit... You could do something like search & replace to change the names.
Ok, if you confirm me that changing "object" with "filename" don't broke the OBJ file, I'll do that.
> It also would not be very difficult for me to write a small program for you that would process the file like that, but it is late over here
> right now so I'll have to look at that tomorrow.
I'm not asking for that.... take ALL the time you want!
>Maybe hide all the other objects except for the ones you want to export? That way you can more easily re-select them with Ctrl+A if >they are the only visible objects.
I'll do that. Haven't think about it!
Thanks for the unbelievable support!
Luca
