Unable to create Direct 3D9 device
1830.4 In reply to 1830.3
>Another thing you can try is to go to Start/Run and type in dxdiag.exe - that will run the DirectX Diagnostic Tool. On it you can go to the Display tab and there will be a button for "Test Direct3D" - you can hit that to see if Direct3D is working on your system or not.
Dont be scared to UPGRADE the Direct X also. This page shows you the version you have. Shoud say at least 9c or something like that!
[EDIT]
Also if the reboot doesnt fix it and it was working a week ago, it could be a color depth or resolution setting. Did you change this? (New monitor, etc.) [EDIT]
EDITED: 29 Jul 2008 by BURRMAN
