Bolts - Any way to create a macro-scipt ?
1823.2 In reply to 1823.1
Hi PaQ - circle should actually grab its orientation just by the first point that you pick, so it shouldn't be necessary to actually do that 3rd step of moving the mouse.
Some commands like line, polyline, rectangle from corners do only orient themselves if you pick 2 points snapped on to a planar surface, but circle has a higher level of snappy-ness than that, it will orient itself just by the single first pick.
I think it should not be difficult to make a "QuickCircle" command that will plop circles down with a single click, I'll see if I can cook that up for you.
I definitely want to add an function along the same lines as the "paste on surface" that you are talking about too, it will probably be added as a Transform/Orient command I think.
