NURB Tutorial for Architecture
1818.14 In reply to 1818.8
Hi Anis,
> Michael, is it difficult to add a "double line" tool that will
> very helpful when creating a wall ?
It is quite a bit of work to do one that does the full "wall stuff", like integrating pieces with existing walls when you draw new pieces, etc ...
I have added it to the wishlist though (http://moi3d.com/wiki/Wishlist).
In the meantime probably the best method would be to draw a polyline for your pieces, and then use Offset to create the "thick lines".
For example if you have an outline like this:
Select it and then run Construct / Offset to create an inner piece a constant distance away from the original:
That combination of Polyline + Offset can give you much of the same type of thing as a double-line tool would.
