Global Issue
1808.6 In reply to 1808.4
""If you re-create those latitude lines using a slightly smaller or larger radius than the longitude ones, then those should carve out better.""
I am pretty sure this would have worked, I did not thought of this solution.
Well, I've managed to do it with the section method. Although I was not able to Union the parts afterward it will do the job for now.
Thanks again!
Marc
