Request advice on panelling spaceships (or what have you)
1792.8 In reply to 1792.7
By the way when you do the latitude lines you'll probably run into a similar problem with the equator line, its edges happen to be very nearly flush with the longitude lines, those kinds of things where edges run very closely along each other can confuse things.
To make the equator latitude line work you should try using a just slightly larger square to sweep along that particular one.
