Hi Petr, yes that is correct - STEP and SAT with both import and export for each.
> But you claimed it was really difficult to write a routines for
> reading in the file.... and now, I hear it is coming true :)
Definitely importing is a much more difficult task.
But it helps speed things up a lot if you license a library that someone else wrote, which is what I did for this case. :) These will be using the HarmonyWare file translator libraries.
I don't really know a whole lot of details about SAT though, like if it tends to be particularly fussy or not, etc...
Is SAT import something that will be of particular use to you?
