I finally done it. Actually I had to come out with another way to make it, it was just a little change, but made the things work. I´ll use the printscreens to try to show the difference and after this little exercice I think I´m understanding better what Fillet can do or what are the conditions to do it.
In the first image [1.1] you can see I the things I used to make it.
1.1
In the second one [2.1] you can see the way I was doing that "border" before. I was using Boolean Diff with the sphere. In the third image [2.2] you can see what happened, I tried but I couldn´t use Fillet in that "border".
2.1
2.2
In the 3.1 you can see what I changed and then the results [3.2 and 3.3]. Well, the last one, as I can´t save and render it, I just used HIDE to hide the lines... hehehe...
3.1
3.2
3.3
