Hi PaQ,
> I know MoI toolset wasn't focused in this area, but I realllly hope this
> kind of tool (especially the continuity stuffs) will appear soon :)
The rebuild one is probably not too far out after I have a good location to put it in some kind of advanced tools menu, probably after some object properties work is done. But it will be a bit longer for the other ones, those are not particularly easy areas. I do plan to have them eventually though.
The missing continuity stuff does not generally prevent you from creating a surface, it will prevent you from getting smoothness, you can still build the basic shape with creases between the different panels though.
But if you absolutely need the continuity control you will need to use Rhino or something like Alias or ICEM Surf for that currently.
> Top priority for me (with a patch tool and a more advanced surface
> blending one that allow multicurve) , ... it's even more important
> (for me) than the object layers management.
I've definitely had a lot more people put object management as a higher priority...
Sorry it is just too difficult to do everything all at once... ;)
