V2 beta Jul-3-2008 available now
1742.10 In reply to 1742.8
Hi Phil,
> Duh....I was in the 3D view. I found them in the other views.
Yeah, that's the biggest downside to the new grips, they show up in the 2D views (Top/Front/Right) for all objects, but they will only show up in the 3D view if you have planar objects selected.
They're essentially a 2D focused thing.
I could put them as a 2D plane going through the middle of objects in the 3D view, or possibly at the bottom of the object's bounding box, but that seemed like it would be kind of weird.
I had also thought about putting them both at the top and bottom of the object's bounding box to get kind of 8 grips as a cube, but it seems like they will start to be getting in the way of stuff and a big goal for those was to make them have a minimal footprint and stay out of your way so that they could be turned on all the time without causing interference.
I still may be able to experiment with some different things for this, like maybe placing it at the bottom of all objects would not be all that bad... But also it is possible that the 3D view will really need a totally different style of manipulator than the 2D frame style.
