| Hi Michael,
 add:3D distance versus projected one
 Could it these alternatives be driven by "Project to plane in ortho view" option?
 >> it should try to use a projected distance instead...
 >>But then should it place the final point on the line's elevation or
 >>on the base point's elevation?
 I rarely want to change all three base point's coordinates of object at the same time while running a move command so I think it should place final point on the base point's elevation there.
 I guess the final point inherits the elevation of base point in case of 3D distance measurement in current implementation(?)
 Petr
