Easies way to create an object in exact location
1727.38 In reply to 1727.37
Hi Danny,
> I was also wondering from going through this post is
> it possible to have a script or command to combine
> circle > position > extrude > boolean diff as a sort of one step hole function ?
It's certainly possible, but it presents a pretty big UI challenge - so far I have tried to shy away from having too many operations that kind of duplicate other things that already have the basic "ingredients" available for them.
That's part of a kind of general effort to avoid UI bloat.
That would probably go in a category with some other operations like Rib, Boss, etc... It's better from a UI perspective to treat these all as a kind of batch set all together, which also kind of ups the bar for the amount of time needed to make them happen.
What I'd like to do before that is to kind of build up the ingredients another step more directly, like make it an option within the current Extrude command to do a boolean built in.
