| Hi Michael,
 > That seemed to be the same as the SolidWorks workflow that was shown where one constraint dimension is added at a time.
 Yes, you're right, what you've done is good, if you could make the command go in a loop, that would be even better.
 I was also wondering from going through this post is it possible to have a script or command to combine circle > position > extrude > boolean diff as a sort of one step hole function ?
 ~Danny~ |
