| Hi Michael....
 >I was thinking a bit about making the command go in a loop
 >to allow you to keep picking new distances and new edges
 >without repeating the whole command.
 >But then that would make you do an extra action
 >to finish the command in just the simple case where you just want to apply one distance...
 Good idea michael, more & more faster...
 >One note - one thing that does not work is if your base point
 >that you first pick is exactly on the target line that you specify
 >next (like if the circle center was already directly on the line).
 >It doesn't know which direction from the line it should move towards in that case.
 Yup, i think this behavior is same in SW. When a the center of circle already connected with a line ( concident ), then we cant move the circle in a specific direction. Because the circle already constraint with the line.
 No problem ( at least for me ).
 Now, I am looking for your another work / idea on "object management / properties".
 Maybe next week ???
 Thanks Michael,
 -Anis
