| > Thats exactly what I looking for.
 Great!  It actually did turn out to be easy to do with just kind of re-arranging the sequence to be more similar to how the Move command currently worked.
 > I wish you will put this feature in V2.
 Yes it will be - that video that I showed was actually v2 in action there. So this will be in the first beta. It should be out pretty soon!
 Please let me know if you run into any problems when you get a chance to use it.
 One note - one thing that does not work is if your base point that you first pick is exactly on the target line that you specify next (like if the circle center was already directly on the line). It doesn't know which direction from the line it should move towards in that case.
 Right now it will just switch to standard point-to-point move in this case, but you can use the regular distance constraint to move by a specific amount in this case already.
