| Hi Pilou,
 > Is there in the V2 something to move the Cline helper by
 > enter a numeric value (as actually rotation) ?
 There is now!  :)
 I just made a change so that the "Relocate cline" will now use a base point (using the cline's start point) for the relocation pick, which means you can now use distance constraint on it in the same way as the Move command.
