Hi Michael and thanks for the UNBELIEVABLE support.
1) The modified mirror command it's perfect fot my needs. Thanks a lot!
3) Here I want explain my problem. I'm not an expert in moi and probably I make some stupid request or error, let me know if it happens too often....
I create the highlighted wall by extruding a profile. After I have created the hole with a boolean operation. How can I change the height of the wall without changing the elevation of the opening? After the boolean operation I cannot use "Show point" for moving down the top face.
4) I've installed the fixed command but it doesn't work (approximatly the same error already reported but in line 70) and with the shortcut key I receive this error:
Thanks for all your hard work.
I'm impatience to test the v2 version of moi.
Grazie
Luca
