Hi JP - don't worry you'll be able to have both side by side on the same machine with no problem, and that will actually be the default way that it gets installed (the v2 beta will go to its own folder).
The only thing shared in common will be the moi.ini settings file, that's it. And actually you can even disable that by copying a separate moi.ini file into each installation's main folder.
