| Oops, missed these 2:
 > Chamfer on a path
 I'm not sure what this one means, is it possible to see an image that explains it?
 > Chamfer/fillet on multiple selection! (now just one selection (bug? )
 It should be working for edge fillets. For example, draw 2 boxes, select both boxes, do a fillet = both boxes are filleted.
 For curves it is different because you either select 2 curves to fillet with each other (which will also extend the curves to meet if necessary), or 1 curve to fillet the internal corners of it.
