looking for help with propeller model
1694.3 In reply to 1694.2
Hi JP, please post here again if that previous windmill wing discussion doesn't get you going.
One quick bit of advice - it can be a lot easier to make things like that if you don't worry so much about the rounded tip part at the very end during the initial modeling part.
I mean focus first on kind of the main body of the propeller, get some curves arranged out similar to this:
Then select them and run Construct/Loft to build a base surface like this:
That's the basic way to get started. Once you have that central form done then you can worry more about the tip and about joining that blade to a central hub, if you get stuck on parts please post a .3dm model file here with your current progress in it, that makes it a lot easier to give advice.
